Demanded ISX? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Demanded ISX? (/showthread.php?tid=7579) |
Demanded ISX? - earnies2 - 07-23-2021 what sensors should be replaced in a demanded 871 2009 ISX? RE: Demanded ISX? - tree98 - 07-23-2021 Imap and exhaust gas pressure. RE: Demanded ISX? - earnies2 - 07-23-2021 (07-23-2021 )tree98 Wrote: Imap and exhaust gas pressure.If I remember wasn't there a terminal clipped out of one of the sensors? RE: Demanded ISX? - earnies2 - 07-23-2021 (07-23-2021 )tree98 Wrote: Imap and exhaust gas pressure.And I would also clean the tube to the exhaust pressure sensor. RE: Demanded ISX? - tree98 - 07-23-2021 (07-23-2021 )earnies2 Wrote:(07-23-2021 )tree98 Wrote: Imap and exhaust gas pressure.If I remember wasn't there a terminal clipped out of one of the sensors? No nothing like that. Just put a new one on and plug it in, don't modify it in any way. Yea clean the tube or just replace it if it's fairly old or was on a mandated engine for most of it's life. |
