| Repairing a VGT - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Repairing a VGT (/showthread.php?tid=7684) |
Repairing a VGT - onebadapple - 09-03-2021 CM 2350 Has anyone repaired a turbo with a sticky arm? With the engine cold the VG arm moves freely like it is supposed to. Did a “hot” test a few days ago: Got it to operating temperature then drained the antifreeze and had the actuator off in less than fifteen minutes. The arm moved freely about 7/8s of it’s travel then a sticky spot when pushing it to the right. This could explain some of the issues I’ve had recently. Is there a way to repair this without installing a new 5K+ turbo? RE: Repairing a VGT - tree98 - 09-03-2021 No you won't be able to do it yourself. Call YTS down in Georgia, they reman turbos better and cheaper than a OEM Cummins. |
