Headlight issue. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Headlight issue. (/showthread.php?tid=7689) |
Headlight issue. - PuroCumminsPower - 09-04-2021 [attachment=8036]My headlight on driver side went out so I went to replace bulb and found this issue with the wire. I replaced bulb and had to position wire in a certain way to make a better connection. It holds but every once in awhile with all the bumps on road it will go out then on again. Does anyone know what the part # is and can I just cut and reconnect the wire? RE: Headlight issue. - Chamberpains - 09-04-2021 Looks like a standard metri pac connector. https://amzn.to/3n1oefl RE: Headlight issue. - SquareOne - 09-04-2021 Yep, I actually just went to Oreily's Auto parts, bought a new pigtail and replaced it. Little twisting, solder, and heat shrink...looks factory once back in the loom. Now I don't wink at people every few nights lol |
