| Remove A/C Schrader valves without discharging the system - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Things that may help others... (/forumdisplay.php?fid=46) +--- Thread: Remove A/C Schrader valves without discharging the system (/showthread.php?tid=7713) |
Remove A/C Schrader valves without discharging the system - Chamberpains - 09-15-2021 Call me slow if this tool is common knowledge but damn, I just found out from my HVAC buddy that they have a tool that can remove and replace Schrader valves without totally discharging the system. Here's a what a quick Amazon check found MASTERCOOL (81490 R134A Valve Core Remover Installer, Yellow Gold, 6.8 inch https://amzn.to/3nywPGC And here a YouTube video I watch to see how it works. This is a house unit but the concept is the same. https://youtu.be/t69uLxmM5XE RE: Remove A/C Schrader valves without discharging the system - SquareOne - 09-15-2021 Pretty slick idea... we’d be in the same boat, because I had never thought to even look for a tool like that. RE: Remove A/C Schrader valves without discharging the system - Rawze - 09-15-2021 I have a set of those. Problem is that on a prostar, it does not fit due to the valve pointed directly at the firewall on the low pressure side. RE: Remove A/C Schrader valves without discharging the system - JMBT - 09-15-2021 I have a set too, that I use on my old Volvo. RE: Remove A/C Schrader valves without discharging the system - SquareOne - 09-15-2021 (09-15-2021 )Rawze Wrote: I have a set of those. Problem is that on a prostar, it does not fit due to the valve pointed directly at the firewall on the low pressure side. Yeaaa, def seems like the tool would require a decent amount of space. |
