Are Baldwin filters still having issues? - Printable Version
+--- Thread: Are Baldwin filters still having issues? (/showthread.php?tid=7733)
Are Baldwin filters still having issues? - Redland1 - 09-23-2021
Wondering if the Baldwin filters are still having issues are have they been fixed? It’s hard to find a distributor of Fleetguard/Donaldson around me.
RE: Are Baldwin filters still having issues? - Chamberpains - 09-23-2021
I buy my Fleetguard filters on fleabay. There are plenty of wholesale vendors selling on there at local chain prices and it gets delivered to your door.
RE: Are Baldwin filters still having issues? - Redland1 - 09-23-2021
(09-23-2021 )Chamberpains Wrote:  I buy my Fleetguard filters on fleabay. There are plenty of wholesale vendors selling on there at local chain prices and it gets delivered to your door.
IMO With all the knockoffs you are risking it buying them off of EBay and that just got me thinking about Baldwin counterfeit’s.I used to use Baldwin’s on my Duramax years ago and remember that there was issues with them being counterfeited and this used to be on the Baldwin website https://vicfiltration.co.za/wp-content/uploads/2018/03/Counterfeit-Product-Identification.pdf
So know I’m wondering if the Baldwins with the gasket issues were counterfeit.
RE: Are Baldwin filters still having issues? - Rawze - 09-23-2021
(09-23-2021 )Redland1 Wrote:  Wondering if the Baldwin filters are still having issues are have they been fixed? It’s hard to find a distributor of Fleetguard/Donaldson around me.
ANY brand/style oil filter that simply has an 0-ring in it is subject to cause total engine failure. Fleetguard changed their design a long time ago to have flappers and a rubber seal to prevent just this problem.
If you not sure ... simply take a pic of the filter in the area that it screws on and post it here.
RE: Are Baldwin filters still having issues? - hookliftpete - 09-23-2021
Partandfilters.com for me. Usually pretty quick shipping. Finditparts is another with good prices.
RE: Are Baldwin filters still having issues? - Volvo8873 - 09-23-2021
I also buy my filters from partandfilters.com. They are definitely genuine!
Also look at who you are buying from. Just because you got the steal of a deal to wheel away with from a seller with a 2 score feedback rating on eBay does not mean they are legit. That shi#t happens ALL the time with sellers on there.
RE: Are Baldwin filters still having issues? - RollinCoal - 09-24-2021
I personally favor OEM filters
Fleetguard for my red engine
wifes car goes to ford steelershits for service
RE: Are Baldwin filters still having issues? - Redland1 - 09-24-2021
IMO With all the knockoffs you are risking it buying them off of EBay and that just got me thinking about Baldwin counterfeit’s.I used to use Baldwin’s on my Duramax years ago and remember that their was issues with them being counterfeited and this used to be on the Baldwin website https://vicfiltration.co.za/wp-content/uploads/2018/03/Counterfeit-Product-Identification.pdf
