| 871 exhaust manifold slip joint seals - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: 871 exhaust manifold slip joint seals (/showthread.php?tid=7751) |
871 exhaust manifold slip joint seals - LTWON - 10-03-2021 Need to replace mine as it’s leaking on the forward most piece close to the thermostat. Is there a special way or tool to do this or drive it in like a wheel seal type thing? I see these seals are around $45-50 a piece so don’t want to tear it up. RE: 871 exhaust manifold slip joint seals - Rawze - 10-04-2021 a pvc pipe coupler from home depot that is shaved slightly fits them real nice for installing them. Make sure you do not install it backwards.. I seen a lot of people do that then wonder why its still leaking. |
