| Will a Glow shift oil temperature gauge sender fit on a cm870? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Will a Glow shift oil temperature gauge sender fit on a cm870? (/showthread.php?tid=7767) |
Will a Glow shift oil temperature gauge sender fit on a cm870? - Redland1 - 10-13-2021 My oil temp gauge hasn’t worked since I purchased my truck so I purchased an OEM used one and it didn’t work either.So I’m wondering if the Glow Shift oil temp gauge sender will work on a cm870? And also where would it hook up? TIA. RE: Will a Glow shift oil temperature gauge sender fit on a cm870? - RollinCoal - 10-13-2021 I have a set of there gauges in my dodge. they look good but there sensors are pure shi#t First one last maybe a year and started pouring fuel from it, this ones a few months old and is not very accurate (within a couple psi) RE: Will a Glow shift oil temperature gauge sender fit on a cm870? - Redland1 - 10-13-2021 (10-13-2021 )RollinCoal Wrote: I have a set of there gauges in my dodge. they look good but there sensors are pure shi#t Will I be better off with a Teltek? |
