| How do I jack up the cab on 03’ International 9900 to replace cab mounts? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: How do I jack up the cab on 03’ International 9900 to replace cab mounts? (/showthread.php?tid=7781) |
How do I jack up the cab on 03’ International 9900 to replace cab mounts? - Redland1 - 10-16-2021 Does anyone know how I can Jack the cab up on an 03 International 9900i so that I can replace the cab mounts? RE: How do I jack up the cab on 03’ International 9900 to replace cab mounts? - arch_stanton - 10-16-2021 on my peterbilts I use a floor jack and put a 4x4 cut to the right length in the lift saddle to lift the cab then block it off the frame or the ground with another 4x4 for Safty. RE: How do I jack up the cab on 03’ International 9900 to replace cab mounts? - Rawze - 10-17-2021 Maybe this helps.... |
