| CM2250 fuel pump rebuild - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM2250 fuel pump rebuild (/showthread.php?tid=7785) |
CM2250 fuel pump rebuild - Truckdriven - 10-18-2021 I bought a 2012 kenworth with 620k and want to rebuild the fuel pump because even though the entire fuel pump has been replaced I don't know what mileage. Do I need to replace the head assembly or only the barrel and plunger kits? Is there check valves built into the head that can fail? If they fail will they destroy the engine or simply not run properly? Lifters will also be replaced RE: CM2250 fuel pump rebuild - tree98 - 10-18-2021 Here's how you check the head. If it's ok just replace barrel's and plungers https://youtu.be/wKLV4gAUl6o No bad check valves won't cause engine damage, but if your rail won't hold pressure because of leaking check valves you will overwork that pump and eventually cause premature failure. RE: CM2250 fuel pump rebuild - Truckdriven - 10-18-2021 Yes the check valves pass when check like that video. I'm assuming a leak down test would be the way to check if the rail is holding pressure? RE: CM2250 fuel pump rebuild - Rawze - 10-18-2021 (10-18-2021 )Truckdriven Wrote: Yes the check valves pass when check like that video. I'm assuming a leak down test would be the way to check if the rail is holding pressure? yup... <iframe id="lbry-iframe" width="560" height="315" src="https://odysee.com/$/embed/isx-injector-leak-test-for-the-cm2250/e8187fb8d70f0f06388b597cb40751c5536d03dd?r=8p8MjqctPT8PafuYA5mftGueGF8L3how" allowfullscreen></iframe> RE: CM2250 fuel pump rebuild - GhostHauling - 10-18-2021 Please Update if you find the Rebuild kit and where you got it ? I’ve still yet to find the parts from the dealer the only place they be been able to find them is eBay and I don’t want to risk it with something so important. Mr. Hag I believe has these kits or at least knows where to find them I’m assuming based on my conversation with him a month ago but that was with him doing the work and I haven’t been that far south in 8 months RE: CM2250 fuel pump rebuild - Truckdriven - 10-18-2021 (10-18-2021 )GhostHauling Wrote: Please Update if you find the Rebuild kit and where you got it ? I’ve still yet to find the parts from the dealer the only place they be been able to find them is eBay and I don’t want to risk it with something so important. Mr. Hag I believe has these kits or at least knows where to find them I’m assuming based on my conversation with him a month ago but that was with him doing the work and I haven’t been that far south in 8 months My nearest Kenworth dealer is Shartlesville pa, they do not have any at that location but have 9 among all 9 locations and they will transfer parts from other locations for me when they need to. Interestingly only 2 locations have more than 1 in stock most have 1 in stock and some have 0. That is for the barrel and plunger kit. RE: CM2250 fuel pump rebuild - Truckdriven - 10-18-2021 (10-18-2021 )Rawze Wrote:(10-18-2021 )Truckdriven Wrote: Yes the check valves pass when check like that video. I'm assuming a leak down test would be the way to check if the rail is holding pressure? Leak down was 322 psi in a minute, easily passing cummins spec |
