| Faulty Oil pressure sender? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Faulty Oil pressure sender? (/showthread.php?tid=7809) |
Faulty Oil pressure sender? - Redland1 - 10-28-2021 https://imgur.com/a/IuNh6WZ RE: Faulty Oil pressure sender? - SquareOne - 10-28-2021 Not sure what runs the needles on those, but I have seen stepping motors in other applications become erratic over time. The voltage gauge seems to be doing the same thing as well. Whats the specs on the truck...maybe someone with a similar one will chime in soon. RE: Faulty Oil pressure sender? - Redland1 - 10-28-2021 (10-28-2021 )SquareOne Wrote: Not sure what runs the needles on those, but I have seen stepping motors in other applications become erratic over time. The voltage gauge seems to be doing the same thing as well. Whats the specs on the truck...maybe someone with a similar one will chime in soon. 2003 International 9900I RE: Faulty Oil pressure sender? - Rawze - 10-28-2021 monitor the oil pressure in Insite and see if the ECM thinks its jumping like that too. RE: Faulty Oil pressure sender? - Redland1 - 10-28-2021 (10-28-2021 )SquareOne Wrote: Not sure what runs the needles on those, but I have seen stepping motors in other applications become erratic over time. The voltage gauge seems to be doing the same thing as well. Whats the specs on the truck...maybe someone with a similar one will chime in soon. 2003 International 9900I |
