| Kenworth w900b window motor replacement - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Things that may help others... (/forumdisplay.php?fid=46) +--- Thread: Kenworth w900b window motor replacement (/showthread.php?tid=7836) |
Kenworth w900b window motor replacement - Precisionw900 - 11-08-2021 I needed a window motor for my w900b and they only offer it as the complete regulator assembly to the tune of $450!!!!and no cross references for the factory part numbers. Damn dealers are crazy. So after a lot of searching dimensions and measuring my mounting and sprocket sizes I came up with a Dorman 742-251 window motor that can be found on eBay or amazon or a dozen other places for about 40$. Perfect fit in case anyone has ran into this figured it would help. RE: Kenworth w900b window motor replacement - Chamberpains - 11-09-2021 Being kenworth used a lot if the same parts year after year on many different models I'll bet this works on more than just the w900b. What year is your truck? RE: Kenworth w900b window motor replacement - Precisionw900 - 11-09-2021 (11-09-2021 )Chamberpains Wrote: Being kenworth used a lot if the same parts year after year on many different models I'll bet this works on more than just the w900b. I would wager that your correct. My truck is a 2004. I do know that many of the interior panels, bezels and cab parts do cross over to a w900L. |
