| Heated mirrors - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Heated mirrors (/showthread.php?tid=7883) |
Heated mirrors - Yauchout - 12-03-2021 The heated mirror light on my dashboard flashes when I turn on my heated mirrors in my lonestar but here's the thing the heated mirrors work while it's flashing I'm getting a code that says heated mirror circuit open or current below normal does anybody know what these needed mirrors are supposed to ohm in at RE: Heated mirrors - Rawze - 12-03-2021 Start by replacing all the tarnished fuses in the fuse panel. Solves a lot of those ghost types of issues with the cab controller. ref: http://rawze.com/forums/showthread.php?tid=1514&pid=12861#pid12861 RE: Heated mirrors - Nilao - 12-03-2021 Had to replace the mirrors in my prostar for that flashing. The BCM monitors the circuit and if the current is below a preprogrammed amount it flashes the switch. |
