| ISX15 low power egr tune up guidance - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: ISX15 low power egr tune up guidance (/showthread.php?tid=7884) |
ISX15 low power egr tune up guidance - Hotshot - 12-03-2021 I'm looking for help locating Rawze's guidance for the isx15 egr tune up. If someone could please help me with a link or two? Truck is 2011 400 hp 688k Thanks, Ray RE: ISX15 low power egr tune up guidance - tree98 - 12-03-2021 https://youtu.be/FhJxpyS5MpY The engine in the video is the slightly older version of the isx than yours but all the same things apply. {assuming it is a CM2250/common rail engine} ... You also need to rebuild your fuel pump YESTERDAY if it hasn't been done yet. It's nothing to play around with. RE: ISX15 low power egr tune up guidance - Hotshot - 12-12-2021 Thank you much. Exactly what I needed and yes I had the pump redone and put in a new regulator |
