| 2013 Pete 365 relays - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: 2013 Pete 365 relays (/showthread.php?tid=7901) |
2013 Pete 365 relays - AyronP - 12-13-2021 Hi, does anyone have a relay diagram for a 2013 Pete 365? This truck just shuts off like someone turned the key off, it's intermittent and in insite it shows shutdown....I feel like the ignition relay is sus.. RE: 2013 Pete 365 relays - Rawze - 12-13-2021 Its can also be a problem with the wiring from the battery to the ecm. Here is a similar thread describing similar problems on an older model truck... maybe a direction to look into.. ref: http://rawze.com/forums/showthread.php?tid=469&pid=3505#pid3505 RE: 2013 Pete 365 relays - AyronP - 12-14-2021 Thanks man I'm checking it now RE: 2013 Pete 365 relays - AyronP - 12-14-2021 Well this issue shows more of its colors Idling the truck will momentarily cut off then turn back on. When it does turn off traction/stability control lights come on and the trip, miles and temp disappear from from gouges. Def gauge read empty and when I slammed the door out of frustration everything came back on... RE: 2013 Pete 365 relays - Rawze - 12-14-2021 (12-14-2021 )AyronP Wrote: Well this issue shows more of its colors when you narrow it down let us know what it is + maybe some pics ... so that the next guy will not have to suffer the same fate? have you tried smacking the ecm with something (almost hard enough to dent it but not quite denting it) and see if it cuts out?. The older CM871 ecm's were bad about that after they have 8+ years of service life on them... and/or if the crank shaft damper was not changed at 500k miles like it should be, and the extra engine vibration finally got it. This goes back to lack of any proper engine care/maintenance, past changing the damned oil. RE: 2013 Pete 365 relays - AyronP - 12-14-2021 I did smack it a bit perhaps I'll try it again |
