| A forewarning or a quirk? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: A forewarning or a quirk? (/showthread.php?tid=791) |
A forewarning or a quirk? - Mrkentee - 08-23-2016 I got my first CEL in a long time. It stayed on for a few seconds and went off. It was for the turbo actuator, which is about 8 months old. Have others had something like this that came and went, or should I be expecting more? Thanks RE: A forewarning or a quirk? - gearhead - 08-23-2016 It may have got stuck for a second what was the code number RE: A forewarning or a quirk? - Mrkentee - 08-23-2016 (08-23-2016 )gearhead Wrote: It may have got stuck for a second what was the code number SPN 641 FMI 7. Description 2387 Amber VGT Actuator Driver Circuit (Motor) - Mechanical System Not Responding or Out of Adjustment RE: A forewarning or a quirk? - gearhead - 08-23-2016 If it does it again then you might want to start checking into it. |
