| Govener speed set up - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Govener speed set up (/showthread.php?tid=7920) |
Govener speed set up - nirubini - 12-20-2021 Hi I HAVE A 2013 ISX 15, I NEED TO SETP UP MY SEMI TRUCK GOVENER SPEED . CAN ANY ONE HELP WITH THAT? I WANT TO SPEED LOCK MY TRUCK. ANY VIDEO ? I HAVE A INSITE 6 RE: Govener speed set up - MageRoyal - 12-20-2021 look in features and parameters on Insite. Simply set it to what u want and send changes. RE: Govener speed set up - RollinCoal - 12-21-2021 Under features and parms Max road speed Cruse speed Max RPM without road speed set to 12-1400 = this keeps people from unplugging the speed sensor to disable the speed limit RE: Govener speed set up - Chamberpains - 12-24-2021 (12-21-2021 )RollinCoal Wrote: ... Doesn't this also put you in a limited rpm state if the speedo circuit would fault out? I put mine at 1850 so I can drive it normally without the speed sensor for that very reason |
