|  Cm2350 passive regen hours - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Cm2350 passive regen hours (/showthread.php?tid=7984)  |
Cm2350 passive regen hours - Carhauler - 01-23-2022 Got a 2350. When on insite looking at the hour counter for active or passive regen, I noticed the passive regen hasn’t happened in a couple thousand hours. Truck only active regens a couple times a month and the dpf differential is well under 1 and outlet is about the same. I’m just curious why the truck isn’t picking up on passive regen. I run back and forth on i90 in Washington twice a day all week so there are plenty of big hills. Thanks.  |
