oil additives? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: oil additives? (/showthread.php?tid=8021) |
oil additives? - maxwell_smith - 02-07-2022 What kind of oil additives do you run? i have seen what Lucas has done to bearing and won't put it in my motor and have been considering using motorkote. I would like to see a dyno test before and after adding it to see an increase in power to back up their "hyper lubricant" claims. RE: oil additives? - marek4792 - 02-07-2022 Stay away from them. Most are no good and are detrimental to your engine, and they are banking on the placebo effect at the expense of your engine. Alot of us here use one gallon of 80/90 gear oil. There was a thread on here where Rawze broke down what those supposed additives have in them. RE: oil additives? - hhow55 - 02-07-2022 I use supertech, the one from Walmart. RE: oil additives? - maxwell_smith - 02-10-2022 Thanks for the info. |
