Cm2350 and cm870 deregulated - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Cm2350 and cm870 deregulated (/showthread.php?tid=8039) |
Cm2350 and cm870 deregulated - Luckyjayb - 02-10-2022 Does anybody know the part numbers for the coolant lines to replace the egr cooler on a cm 2350x101 and cm870? I thought I had them somewhere but seem to have lost them. Thanks for the help. RE: Cm2350 and cm870 deregulated - smorgan87 - 02-10-2022 If its the same as an x15 2350 "4367222" n theyre 205$. RE: Cm2350 and cm870 deregulated - Rawze - 02-11-2022 registering your engine ser# on quickserv.com and you will have access to all parts and info for your engine. RE: Cm2350 and cm870 deregulated - Luckyjayb - 02-11-2022 (02-11-2022 )Rawze Wrote: registering your engine ser# on quickserv.com and you will have access to all parts and info for your engine. I have the account but didn’t know you can look up stuff that is not on your engine. RE: Cm2350 and cm870 deregulated - Rawze - 02-11-2022 (02-11-2022 )Luckyjayb Wrote:(02-11-2022 )Rawze Wrote: registering your engine ser# on quickserv.com and you will have access to all parts and info for your engine. I think you can register up to 5 different engines for the same e-mail address. After that, a person can use their subscription services (paid yearly). |
