| CUMMINS ECM RECALL! ... - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Things that may help others... (/forumdisplay.php?fid=46) +--- Thread: CUMMINS ECM RECALL! ... (/showthread.php?tid=808) |
CUMMINS ECM RECALL! ... - Rawze - 08-27-2016 According to this article... http://trucker.com/equipment/cummins-recalls-more-5000-engines-potential-ecm-problem And NHTSA Bulliten ... http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM519087/RCLRPT-16E047-6115.PDF (Quoting the article...)" "In a filing with the National Highway Transportation Safety Administration (NHTSA), Cummins said ECM part number 4358814 on ISX12 and ECM part numbers 5317106 and 4358814 on ISX15 engines manufactured from March 7 through April 12, 2016 will be recalled as they may short circuit and blow a fuse, resulting in the engine stalling without warning. More than 5,000 units are potentially affected, according to the notice." ------ 5317106 and 4358814 are both CM2350 ECM's for the ISX12 and ISX15 engines. If you have a new ECM that was replaced, I would check the manufacturing date on it to make sure it does not fall into the recall. RE: CUMMINS ECM RECALL! ... - jorden486 - 09-07-2016 Both of my new trucks had this recall down. My dealer didn't know about it and had a computer overnighted in from Columbus on the first one. |
