CM2450 Remote Tune - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM2450 Remote Tune (/showthread.php?tid=8092) |
CM2450 Remote Tune - JasonD5746 - 03-09-2022 Who is the site "remote tune" guru? I can turn a wrench fairly well, but I want someone with more experience than what I have writing the tune. Recommendations? Thanks 2022 W9 with x15 Performance 565hp 1850-2050tq 70k mi. RE: CM2450 Remote Tune - Rawze - 03-10-2022 If ya just want someone to do things for ya then PM Forum members 'running rough' or 'RollinCoal' or possibly 'Mr. Hag' are likely the ones to talk to if u need someone to do some programming stuffs. Of course, if someone is a bit computer savvy (can copy files and navigate around on their laptop/PC, check e-mail, fill out spread sheets, etc.. the typical stuffs)... Then actually they can likely follow some step-by-steps guides for copying the file into and out of their ecm themselves. If they can do this then it becomes a simply matter of just e-mailing the ecm program and having the 'adjustments' part of it done 100% correctly .. and putting the file back in, costing them pretty much nothing. ref: http://rawze.com/forums/showthread.php?tid=7435&pid=68742#pid68742 |
