| Yaw rate sensor location - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Yaw rate sensor location (/showthread.php?tid=8158) |
Yaw rate sensor location - Mikanic - 04-11-2022 hey guys Im looking for the yaw sensor on a 2015 prostar. I only have bendix wiring diagram, and dont have access to the oem's. I have Fault code 22-3 and 22-5 on 63 counts (bendix EC-60 module) RE: Yaw rate sensor location - marek4792 - 04-11-2022 If this is for the Electronic Stability Control, it's mostly likely under the truck mounted to or near the ABS module on the center of the 1st crossmember just behind the transmission. RE: Yaw rate sensor location - Mikanic - 04-11-2022 ok, I found the sensor but I have not found the ABS module. Are you sure its near the sensor? RE: Yaw rate sensor location - marek4792 - 04-11-2022 Usually it's close by, trace an abs wire from one of your drive axles and it'll lead you to it. RE: Yaw rate sensor location - Mikanic - 04-11-2022 ABS module is under passenger side kick panel. In front of passenger door. |
