Air line for fuel - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Air line for fuel (/showthread.php?tid=8176) |
Air line for fuel - Redland1 - 04-23-2022 I’m in the process of replacing my fuel sender and decided to replaced the fuel lines as well.Noticed that my truck has air lines for fuel.Dated 2000.Can I use new air line or is there only a certain type that is multi use? RE: Air line for fuel - tree98 - 04-23-2022 Not sure...... I've used air line for fuel though, never had a problem. RE: Air line for fuel - Rawze - 04-23-2022 (04-23-2022 )Redland1 Wrote: I’m in the process of replacing my fuel sender and decided to replaced the fuel lines as well.Noticed that my truck has air lines for fuel.Dated 2000.Can I use new air line or is there only a certain type that is multi use? I would not suggest using air lines for fuel. they will get brittle in short order and crack, flake, and be problematic. I also highly doubt the truck maker used air lines for fuel as well. RE: Air line for fuel - marek4792 - 04-24-2022 Volvo uses a plastic style fuel line, completely different from an air line. RE: Air line for fuel - Redland1 - 04-24-2022 (04-23-2022 )Rawze Wrote:(04-23-2022 )Redland1 Wrote: I’m in the process of replacing my fuel sender and decided to replaced the fuel lines as well.Noticed that my truck has air lines for fuel.Dated 2000.Can I use new air line or is there only a certain type that is multi use? I found it odd when I looked at it and saw that it was an air line and when I saw the date of 2000 and my truck is a 2003 I got to wondering if that’s what Navistar used.Is there a specific type of hose that you suggest? RE: Air line for fuel - Nilao - 04-24-2022 Freightliner uses plastic lines also. I would think that compression fittings could be used to retrofit a fuel system from rubber to plastic if needed. RE: Air line for fuel - Nostalgic - 04-24-2022 The blue Aeroquip SAE100R5 air hose I use is rated for hydraulic fluid, diesel, gas, oil, coolant, etc. |
