| Naturally Aspirated Air Compressor - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Naturally Aspirated Air Compressor (/showthread.php?tid=8193) |
Naturally Aspirated Air Compressor - kozakvod - 05-01-2022 I was doing some looking on QS for a code I had and I noticed this on the Service page. Naturally Aspirated Air Compressor Upfit for Kenworth and Peterbilt Can someone please explain what this is? Showing my ignorance I know, but then there's a lot of things that fall into that category for me, so no shame in my shame. I looked at the kit parts and it some how pipes across the engine back into the fresh air side of the turbo, i guess/think? RE: Naturally Aspirated Air Compressor - schISM - 05-01-2022 It’s a retrofit kit for the older ISX’s to plumb the compressor intake into the turbo inlet thereby eliminating the soot from the egr process being introduced into your air tanks, air lines ect. Not really something I’d worry about especially if you’ve already dealt with the soot problem. RE: Naturally Aspirated Air Compressor - kozakvod - 05-01-2022 (05-01-2022 )schISM Wrote: It’s a retrofit kit for the older ISX’s to plumb the compressor intake into the turbo inlet thereby eliminating the soot from the egr process being introduced into your air tanks, air lines ect. Not really something I’d worry about especially if you’ve already dealt with the soot problem. Oh it wasn’t something I was going to do, just didn’t know what it was and yes my soot issues were removed a couple years ago. Thank you, appreciate the response. |
