| good evening!!! Jake brake question - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: good evening!!! Jake brake question (/showthread.php?tid=8199) |
good evening!!! Jake brake question - jjoshthomas074 - 05-02-2022 engine ser# 79147134 cm870 435st code that comes up every time #2366 i have a engine warning light when activating the jakes! i got to reading a little in quickserv and noticed on a 2 solenoid system #1 isn't used. does this mean something in the ECM programming is wrong?? Considering im getting this code!! both jake solenoids ohm 9.5-10 jake harness was just replaced the pass threw connector was getting oil soaked. 5v at all 3 pins at rocker box connector. Thankyou for your time and input! RE: good evening!!! Jake brake question - MommaBurt - 05-04-2022 According to the ESN you gave it should have a 2 engine brake file in it. If it has a 3 engine brake file in it then yes, it will throw that fault code. RE: good evening!!! Jake brake question - jjoshthomas074 - 05-04-2022 What would be the best way to check and resolve the programing?? Cummins Dealer? RE: good evening!!! Jake brake question - MommaBurt - 05-06-2022 Yeah, the easiest way is to hook your engine to insite and see what the ECM code is. We can tell you from there if it is the right file or not. RE: good evening!!! Jake brake question - jjoshthomas074 - 05-07-2022 ECM ser# 26043299 is this what your referring too? if not i can hook up to it tomorrow and get you what your asking for! thankyou for the help. RE: good evening!!! Jake brake question - MommaBurt - 05-09-2022 No, the ECM code will be displayed at the top of Insite next to the serial number. It will be an ABxxxxx number. RE: good evening!!! Jake brake question - MommaBurt - 05-09-2022 If you need help PM me. |
