| No crank - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: No crank (/showthread.php?tid=8219) |
No crank - Jchism3406 - 05-10-2022 Finally got my Truck back together after having the engine out and rebuilding it Turn key on abs went to hit the start button and I have nothing. Starter relay clicking RE: No crank - Rawze - 05-10-2022 starter going bad?. is the engine easy to turn by hand?. RE: No crank - Jchism3406 - 05-10-2022 Yes I apologize. Starter was working before engine disassemble now it doesn’t make any noise or try to engage. What makes the starter engage. The little solenoid under the starter? RE: No crank - Rawze - 05-10-2022 (05-10-2022 )Jchism3406 Wrote: Yes I apologize. Starter was working before engine disassemble now it doesn’t make any noise or try to engage. What makes the starter engage. The little solenoid under the starter? its anyone's guess. you also did not mention what type of truck, engine, etc. RE: No crank - Jchism3406 - 05-10-2022 2001 Peterbilt 379 exhd. Cummins isx cm570 RE: No crank - Signature620 - 05-11-2022 Make sure the cables are connected to the starter motor correctly. Apply 12v to the signal wire on the starter solenoid. If it cranks you have a problem with the wiring, ECM, fuses, keyswitch, etc....If it doesn't crank, the starter has failed. |
