tuning question - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: tuning question (/showthread.php?tid=8230) |
RE: tuning question - SemiSweet - 08-21-2022 My 2350 will push 34-35 when loaded and on the 3rd stage engine brake. I will click it down to second stage if I’m at higher rpm’s just to be safe. My brake tables are factory and engine is tuned by a reputable member. There was a post by unilevers years ago mentioning that you don’t want to see over 35 psi on the brakes on the 2250/2350. RE: tuning question - Rawze - 08-21-2022 (08-21-2022 )Aleeex Wrote: I’m no expert, just asking questions to try to understand more myself. high exhaust back-pressures cause valve closing delays as the engine turns high RPM ... a piston can strike a valve. |
