| Repairing my Chinese Inline 5. It worked! - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Things that may help others... (/forumdisplay.php?fid=46) +--- Thread: Repairing my Chinese Inline 5. It worked! (/showthread.php?tid=837) |
Repairing my Chinese Inline 5. It worked! - preacherboy24 - 09-03-2016 The USB plug in my Inline 5 bit the dust. It just isnt enough plug to be working in the environment it works in. I decided to ditch the plug and just hard wire it to the board. It works like a champ now. If you are having problems you can send it to this guy and he can fix it for you. RE: Repairing my Chinese Inline 5. It worked! - Old Driver - 09-04-2016 There's a good website that sells all sorts of little electronics. I like to use them for stuff like this. Digikey.com |
