Oil pressure gauge problems - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Oil pressure gauge problems (/showthread.php?tid=8395) Pages: 1 2 |
RE: Oil pressure gauge problems - Hemiterry - 09-22-2022 My mechanic checked my oil pressure with insite while driving and it matches my mechanical gauge perfectly. Apparently my problem is between the ECM and the gauge on the dash. RE: Oil pressure gauge problems - Bengy88 - 09-22-2022 It’s most likely a cluster or guage issue. Not saying it definitely is but that’s gonna be the most common if your ecm matches the manual guage but the truck doesn’t. Glad you are getting somewhere with it |
