HVAC AIR COND MICRO RELAY Clicking behind dash. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: HVAC AIR COND MICRO RELAY Clicking behind dash. (/showthread.php?tid=8411) |
HVAC AIR COND MICRO RELAY Clicking behind dash. - Dorito - 08-30-2022 I have a 2016 Peterbilt 389. I’ve replaced the relay. I changed the temperature blender actuator. I put a new belt. I replaced the o rings on the compressor lines.And now a new AC compressor. I also replaced both AC filters and made sure evaporator core was clean. STILL CLICKING!!! Any help would be greatly appreciated! It’s driving me nuts! Lol RE: HVAC AIR COND MICRO RELAY Clicking behind dash. - Nilao - 08-31-2022 That relay is most likely controlled by the body controller. It may need a software update, or it could be sensing some other issue causing it to cycle the relay....you need a shop to hook up ESA and fing out what is causing that issue. RE: HVAC AIR COND MICRO RELAY Clicking behind dash. - Pete365_Tampa - 09-06-2022 (08-30-2022 )Dorito Wrote: I have a 2016 Peterbilt 389. I’ve replaced the relay. I changed the temperature blender actuator. I put a new belt. I replaced the o rings on the compressor lines.And now a new AC compressor. I also replaced both AC filters and made sure evaporator core was clean. STILL CLICKING!!! Any help would be greatly appreciated! It’s driving me nuts! Lol I have a similar issue with this relay...Did you get this resolved? RE: HVAC AIR COND MICRO RELAY Clicking behind dash. - tree98 - 09-06-2022 I had a relay clicking behind the dash in my western star. It turned out to we a bundle of wires rubbing against the starter finally rubbed through and would intermittently ground out. RE: HVAC AIR COND MICRO RELAY Clicking behind dash. - Dorito - 07-12-2023 (09-06-2022 )Pete365_Tampa Wrote:(08-30-2022 )Dorito Wrote: I have a 2016 Peterbilt 389. I’ve replaced the relay. I changed the temperature blender actuator. I put a new belt. I replaced the o rings on the compressor lines.And now a new AC compressor. I also replaced both AC filters and made sure evaporator core was clean. STILL CLICKING!!! Any help would be greatly appreciated! It’s driving me nuts! Lol RE: HVAC AIR COND MICRO RELAY Clicking behind dash. - Dorito - 07-12-2023 (07-12-2023 )Dorito Wrote:(09-06-2022 )Pete365_Tampa Wrote:(08-30-2022 )Dorito Wrote: I have a 2016 Peterbilt 389. I’ve replaced the relay. I changed the temperature blender actuator. I put a new belt. I replaced the o rings on the compressor lines.And now a new AC compressor. I also replaced both AC filters and made sure evaporator core was clean. STILL CLICKING!!! Any help would be greatly appreciated! It’s driving me nuts! Lol |
