| Cm2350 pump head. Dtis vs rebuilding myself - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cm2350 pump head. Dtis vs rebuilding myself (/showthread.php?tid=8439) |
Cm2350 pump head. Dtis vs rebuilding myself - ElJay90 - 09-14-2022 Hey everyone. Still having a hard time finding the parts to rebuild my cm2350 f. Pump head. I've had better luck finding the remanufactured pump head from dtis. Anyone recommend going the latter route RE: Cm2350 pump head. Dtis vs rebuilding myself - amermextrucker - 09-14-2022 (09-14-2022 )ElJay90 Wrote: Hey everyone. Still having a hard time finding the parts to rebuild my cm2350 f. Pump head. I've had better luck finding the remanufactured pump head from dtis. Anyone recommendDTIS ? So it's not a Cummins OEM part ? RE: Cm2350 pump head. Dtis vs rebuilding myself - tree98 - 09-14-2022 Not familiar with DTIS, what is that ? RE: Cm2350 pump head. Dtis vs rebuilding myself - Rawze - 09-19-2022 If it is not an OEM certified component from a certified OEM distributor, then it would be a solid "NO!". |
