| cm870 injector sleeve tools - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: cm870 injector sleeve tools (/showthread.php?tid=8457) |
cm870 injector sleeve tools - hct5 - 09-22-2022 any one know where i can buy the removal and installation tools to R&R an injector cup on a dohc cm870? i know they used to change the cups out , but now they say you need to change the head. RE: cm870 injector sleeve tools - Pigpen 2869 - 09-22-2022 Change the head. RE: cm870 injector sleeve tools - Bengy88 - 09-22-2022 https://static.nhtsa.gov/odi/tsbs/2019/MC-10162096-9999.pdf Check this out, it will answer your question. RE: cm870 injector sleeve tools - Signature620 - 09-23-2022 Do not waste your hopes and dreams on those rubbish blue injector o-rings. They will tear and leave you staring down the barrel of a cylinder head replacement again in a month. RE: cm870 injector sleeve tools - Bengy88 - 09-23-2022 Yup…. What these guys said |
