| In a quandary about EGR cooler - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: In a quandary about EGR cooler (/showthread.php?tid=8463) |
In a quandary about EGR cooler - Mrkentee - 09-26-2022 I’m replacing my turbo. My EGR cooler has over 700k on it, and does not leak. I thought this would be a good time to seal the exhaust ports off, either by welding it closed, or using freeze plugs (I’ve heard it’s feasible). In reality, I don’t want to mess with it, and all the lines, and fittings, and o-rings, etc. what should I do??? Also, is there a kit with all the o-rings and gaskets in it, so as not to have to order them all individually?? RE: In a quandary about EGR cooler - Rawze - 09-26-2022 My egr cooler has 1.4 million on it.. still does not leak. RE: In a quandary about EGR cooler - Mrkentee - 09-26-2022 (09-26-2022 )Rawze Wrote: My egr cooler has 1.4 million on it.. still does not leak. Good enough for me. |
