| ABS J1939 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: ABS J1939 (/showthread.php?tid=8478) |
ABS J1939 - ElJay90 - 10-04-2022 Hey everyone. I've got a fault on the information center that states "ABS J1939". Truck runs great, no derate or other accompanying codes. Truck made it an additional 6 hour drive home after code popping up. I've yet to hook up my laptop and insite to it. Does anyone have any information on this code? Where I should start? Is this best to have an actual mechanic look at? Truck info: 2016 peterbilt 386 ISX15 Manual transmission RE: ABS J1939 - Rawze - 10-04-2022 The hub bearings need re-torquing every 250k miles. When is the last time this was done?. RE: ABS J1939 - ElJay90 - 10-04-2022 (10-04-2022 )Rawze Wrote: The hub bearings need re-torquing every 250k miles. I've only had the truck a short while and don't have that answer. I don't have the proper tools to perform this yet so I'll get it to the mechanic asap to have them re torqued. Thank you rawze. RE: ABS J1939 - windowrattler - 10-04-2022 I would think it was popped by a loss of data communication from the abs module. You might need to use different software than Insite. Jpro is pretty good as a generic software to be able to talk with abs, bcm, cecus, etc in all model trucks. RE: ABS J1939 - jesicat - 10-12-2022 Did it tell you which wheel it's on when you scrolled thru? Maybe check the air gap on your sensor. Sometimes they will vibrate loose in the sleeve. RE: ABS J1939 - Bengy88 - 10-14-2022 With a j1939 fault my first step without proper diag software would be to check fuses and power/ ground supplies to the abs module. Peterbuilts and kenworths are horrible about corrosion in the fuse pannel causing a voltage drop at the fuse. Remember with no power or ground a module can't communicate on the data link which will cause j1939 faults.... Alot of people overlook this and go directly to a non existant j1939 problem |
