Calterm CM2220 metafiles - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Calterm CM2220 metafiles (/showthread.php?tid=8483) |
Calterm CM2220 metafiles - dieselsteve - 10-08-2022 someone please, has any metafile file for isf3.8 cm2220 engine? I need BDP file Thank you RE: Calterm CM2220 metafiles - Rawze - 10-08-2022 rawze.com is NOT A SOFTWARE TRADING SITE!. just an FYI: a 'BDG' meta-file has the same starting address and can be used to copying the file in/out of the ecm (backing it up, restoring it, etc. ) if necessary .. but not for documenting or editing it much. A 'BBN' metafile might also be able to be used for copying in/out of the ecm only too. RE: Calterm CM2220 metafiles - Rawze - 10-08-2022 took a look at the BDP engine files. Looks like they use mode-6 (instead of mode-4) for no-egr operating mode. This is similar to other smaller engines like the ISB's. So anything CM2250 for the ISX is NOT going to be compatible to them. If you have a vehicle that has been de-mandated, and you can copy the file out of the ecm, e-mail it to me, .. I can review it for ya tell you if the de-mandate is any good or not. The most likely scenario is some completely clueless fool trying to use/copy ISX settings on it.. and that would not be good at all. |
