T680 Radio replacement - Reception problems - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: T680 Radio replacement - Reception problems (/showthread.php?tid=8514) |
T680 Radio replacement - Reception problems - Golfnut - 10-26-2022 I replaced the factory radio on my 2014 T680 last week with a Jensen 1635BT unit so I could have bluetooth for both calling and streaming. I didn't not have to use any adapter harnesses. Everything plugged in fine with the exception of a single connector on the truck side that has a blue wire going into it. There is also an unused blue wire on the head unit that is to power an external amplifier. I did not use it. The bluetooth works perfectly fine but I get horrible FM reception and absolutely no AM reception. Where did I go wrong? RE: T680 Radio replacement - Reception problems - Bengy88 - 10-26-2022 Sounds like the antenna wire isnt connected or the antenna or wire is bad. Unless you have a bad head unit thats literally all that has anything to do with your radio signal RE: T680 Radio replacement - Reception problems - Golfnut - 11-13-2022 Evidently these trucks use a powered antenna. I pulled the headunit and spliced together the unused blue wire on the truck to the blue 12v AMP wire on the head unit and reception instantly improved. |
