|  ac high pressure sensor - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: ac high pressure sensor (/showthread.php?tid=856)  |
ac high pressure sensor - ktbtrucking - 09-09-2016 hello, have fan set on high speed all the time under insite it shows air conditioning pressure switch ON All the time, does not matter if air condition is on or off checked solenoid(good), jumped high pressure switch no effect insite says on disconnected low pressure and compressor does not start cant drain the system but bought high pressure and also connected it is always On under insite, also I have the 11v on the switch harness that goes from switch to ecm any thoughts? it is volvo vnl 2002 with cummins isx RE: ac high pressure sensor - Mr Hagg - 09-09-2016 This is for the pressure switch on the firewall.It is a 3 wire switch. It controls the fan for the engine RE: ac high pressure sensor - ktbtrucking - 09-09-2016 have a truck 2004 and it has a 3 wire ac switch on firewall and i believe it measures both high and low 2002 truck has two switches one for low and one for high high is next to radiator and low under the air filter this is what i have figured out so far on my 2004 truck when I turn ac on/off inside the cab insite also changes on/off the name "air conditioner pressure switch" on my 2002 truck insite all time shows "air conditioner pressure switch" ON so that keeps fan on high speed, also supplied "air" to radiator than it slows down looks like ecm related issue for me i assume tri wire switch on the firewall refers to ac switch or there is another one???  |
