| X15 CM2350 Broken Wire on connector to EGR Valve - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: X15 CM2350 Broken Wire on connector to EGR Valve (/showthread.php?tid=8585) |
X15 CM2350 Broken Wire on connector to EGR Valve - BrandonOlsen - 11-25-2022 Is there a way to patch this until I can get a new one that’s back ordered and no date on when it will be available? Or if anyone has one or knows someone that has one ? Looked online and every place that shows they have one I call and they are actually out. The other ones that have them are scam websites. Part # 5394271 2017 x15 cm2350 X114B RE: X15 CM2350 Broken Wire on connector to EGR Valve - marek4792 - 11-25-2022 Is it losing connection because the tab is broken? If that's the case a couple small zip ties will work in a pinch to hold the plug together, until you can get a replacement assuming the wire inside isn't broken. RE: X15 CM2350 Broken Wire on connector to EGR Valve - BrandonOlsen - 11-25-2022 (11-25-2022 )marek4792 Wrote: Is it losing connection because the tab is broken? If that's the case a couple small zip ties will work in a pinch to hold the plug together, until you can get a replacement assuming the wire inside isn't broken. It’s the wire behind the tab. Looks to be 3 wires behind the tab and I circled the top wire that’s split RE: X15 CM2350 Broken Wire on connector to EGR Valve - windowrattler - 11-25-2022 Should be able to de-pin the wire from the connector and get a new pin to re pin it or re use the pin with a new wire. RE: X15 CM2350 Broken Wire on connector to EGR Valve - Waterloo - 11-26-2022 My local International dealer sold the pins for the International side of my truck. They make a little kit that has the tools you need to safely remove the old pins. I have also seen automotive pins at my local Advance Auto. Here is a random kit that popped up. Cannot say it is good or not, but similar to what I use. https://amzn.to/3gDaPJK RE: X15 CM2350 Broken Wire on connector to EGR Valve - RollinCoal - 11-26-2022 Google says 2010-2021 ISX How many you need? I have like 5 trucks with bad engines we use for parts (used of course) RE: X15 CM2350 Broken Wire on connector to EGR Valve - BrandonOlsen - 11-26-2022 (11-26-2022 )Waterloo Wrote: My local International dealer sold the pins for the International side of my truck. They make a little kit that has the tools you need to safely remove the old pins. I have also seen automotive pins at my local Advance Auto. That’s looks like a good kit to keep. Never know when you’ll need it like me LOL RE: X15 CM2350 Broken Wire on connector to EGR Valve - BrandonOlsen - 11-26-2022 (11-26-2022 )RollinCoal Wrote: Google says 2010-2021 ISX Just need 1! I’ll pm you! |
