| SPN 108 FMI 2 isx 2350 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: SPN 108 FMI 2 isx 2350 (/showthread.php?tid=8599) |
SPN 108 FMI 2 isx 2350 - Philroy - 12-02-2022 Demandated isx2350 SPN 108 FMI 2 indicated one of the pressure sensors just not sure which one. What one should I start with? RE: SPN 108 FMI 2 isx 2350 - Rawze - 12-03-2022 isn't that a fault for the barro sensor intermittent signal?. -- cummins Fault code 295?. bad barro sensor or wiring to it? I know that it checks it against the exhaust manifold pressure sensor before engine start.... so you should ensure that sensor is fairly new and its feed-circuit thru the thermostat housing is not blocked up too. |
