Injector leak test kit - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Injector leak test kit (/showthread.php?tid=8600) |
Injector leak test kit - Petegraintrain - 12-02-2022 I ordered an injector leak test kit but it didn't come with a gasket. Do you need a gasket? In Rawze's video he puts on a gasket. Mine has the o ring in the hole but no gasket for the plate. RE: Injector leak test kit - hhow55 - 12-03-2022 If Mr Rawze does it, it's important to do.............lol I bet your local auto part's house could help RE: Injector leak test kit - Rawze - 12-03-2022 as long as it seals, it should work?. RE: Injector leak test kit - Nilao - 12-03-2022 I think the oring takes the place of the metal gasket. The new actuators use orings unless I'm mistaken. |
