| Rod and Main bearings - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Rod and Main bearings (/showthread.php?tid=8628) Pages: 1 2 |
Rod and Main bearings - kozakvod - 12-13-2022 2013 ISX15 cm 2350 I have ordered parts directly from cummins. I have them, I think, but my ignorance is obviously showing up too. What they sent me: 7 sets 14 total (top and bottom) main bearings 2 sets 4 total (top and bottom) some sort of rings? Main 1 set 2 total (top and bottom) rod bearing Is this right? RE: Rod and Main bearings - Signature620 - 12-13-2022 The mains are right. The half moon rings are thrust bearings that go on the 4th bearing cap. They have left you 5 rod bearings sets short however. RE: Rod and Main bearings - Rawze - 12-13-2022 (12-13-2022 )kozakvod Wrote: 2013 ISX15 cm 2350 You also need to take the time to verify every single part# for every single bearing shell that comes out as the old ones are removed. Although it is uncommon, (about a 20% chance) that there is can be an alternate size bearing on a crank or mains lobe randomly inside the engine. A single or multiple crank lobes can sometimes have been installed at the factory to compensate for journal clearances, as the engine goes down the assembly line. There is no way of knowing before hand until the old ones that come out are checked individually. This is per individual lobe, etc.. so every single one has to be checked carefully. Get one wrong and the engine will suffer mysterious low oil pressure issues or some other problem.. and/or can eventually snap the crank. RE: Rod and Main bearings - kozakvod - 12-13-2022 (12-13-2022 )Rawze Wrote:(12-13-2022 )kozakvod Wrote: 2013 ISX15 cm 2350 Rawze thank you for that heads up I will definitely make note to check them. Is what Cummins sent me correct? Is it only a single Rod bearing (2 lobes)? I'll forward images. RE: Rod and Main bearings - kozakvod - 12-13-2022 Two images: Main bearings Rod bearing RE: Rod and Main bearings - tree98 - 12-13-2022 Yea you just need to order 5 more, but first you need to know if all part numbers are the same. I don't think cummins sells rod bearings as a set of 6. I believe you have to buy them individually. RE: Rod and Main bearings - SquareOne - 12-13-2022 (12-13-2022 )tree98 Wrote: ....but first you need to know if all part numbers are the same.... Are those part numbers stamped on the outside of the bearing? I'm assuming verification for ALL bearings, correct? *edit - reread Rawze's post about verifying each bearing PN. RE: Rod and Main bearings - kozakvod - 12-13-2022 (12-13-2022 )tree98 Wrote: Yea you just need to order 5 more, but first you need to know if all part numbers are the same. I don't think cummins sells rod bearings as a set of 6. I believe you have to buy them individually. That was my assumption that this was only for ONE rod bearing! Oh the ignorance of some people is worse than mine and they work for Cummins. I told her I needed full set of rod and main bearings. Who the hell replaces ONE rod bearing? Geezzz I'll verify all part number stamps once I get them all in now that I need to order 5 more. RE: Rod and Main bearings - kozakvod - 12-13-2022 (12-13-2022 )SquareOne Wrote:(12-13-2022 )tree98 Wrote: ....but first you need to know if all part numbers are the same.... Yes they are stamped on the outside of each bearing, I haven't yet opened the packaging of the main bearings, but the ONE rod bearing I have are: 3686435 Upper 3686436 Lower |
