Sleeper blower issues - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Sleeper blower issues (/showthread.php?tid=8687) |
Sleeper blower issues - aarmon89 - 01-12-2023 I have a 15 prostar and i’am having issues with my sleeper blower turning on intermittently whenever it wants. It’ll even turn on when the truck is off and I have no clue as to why—which in turn eventually kills my battery if the truck sits for a few days RE: Sleeper blower issues - Waterloo - 01-12-2023 Do you have the bunk temp/fan controls in your dashboard? Sounds like either a faulty switch, happens, but still rare… Or, a bad relay switch. Where is the relay for the bunk fan? Good question, as I have no clue. I would look in the fuse panel first, there are relays in there. If there is a blower motor or rear HVAC relay, you can pull it for a few days and see if that solves it, or simply replace it. That is where I would start. RE: Sleeper blower issues - Rawze - 01-13-2023 (01-12-2023 )aarmon89 Wrote: I have a 15 prostar and i’am having issues with my sleeper blower turning on intermittently whenever it wants. It’ll even turn on when the truck is off and I have no clue as to why—which in turn eventually kills my battery if the truck sits for a few days When the brushes in the fan motor start going bad they run intermittently. should also not rule this out either... ref: http://rawze.com/forums/showthread.php?tid=1514&pid=12861#pid12861 |
