| charge air cooler - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: charge air cooler (/showthread.php?tid=8723) |
charge air cooler - flonly - 02-02-2023 Anyone have any reviews on TRP brand charge air coolers?Went to kenworth and they can get oem one for 2626.25 or TRP brand for 1110.92 plus both need a kit for 156.89 to be able to install .I guess the kit is needed cause its a 2008 t660 and pacar probley changed even the oem cooler somehow.The guy said one of the brakets needs changed and it comes with longer bolts.So if they changed something from original oem is it going to be really the same as original ? RE: charge air cooler - Rawze - 02-02-2023 TRP brand is owned by paccar and is a part of their oem network of suppliers. RE: charge air cooler - flonly - 02-02-2023 Thanks rawze do you think it will be as good or is there a way to find out if the specs are the same RE: charge air cooler - Rawze - 02-02-2023 (02-02-2023 )flonly Wrote: Thanks rawze do you think it will be as good or is there a way to find out if the specs are the same just count up the number of passage-ways across vs. your old OEM one and if they are the same, it should be good. |
