Cm870 tuning issue needs some help - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cm870 tuning issue needs some help (/showthread.php?tid=8726) |
Cm870 tuning issue needs some help - Sledpuller - 02-03-2023 We are having an issue getting the Ecm to load a tune. It’s failing at 70% every time preparing to load the tune. We have tried loading with a bench harness with same result. Truck is a 2004 Mack cl733 with 565 cm870. I’m using a new nexiq 3 usb wired. I’m working with very helpful and recommend tuner from here. I know it’s possible the Ecm is toast. But just want to make sure before I purchase new one from cummins ($2600). I have a friend from cummins I’m meeting tomorrow to see if he can load a stock file on it with his laptop and software. Truck is stuck at my house dead in the water. Any help is greatly appreciated. Would really like to get back to work Monday. Thanks RE: Cm870 tuning issue needs some help - Rawze - 02-03-2023 I was asked about this earlier this evening. I know that different programs, etc. were tried, so it is not likely the program itself, however it can be the laptop or other hardware. Using a different computer, different adapter (cummins instead of nexiq) and/or different flash method might reveal the issue. Things like switching to the J1708 (or J1939 can bus #2) thru the dash etc. instead of a bench harness, etc.. sometimes yields different results. some thoughts... * anti-virus software or other USB scanning software on the PC will interfere with flashing an ecm. * Sometimes having an older cummins inline-5 adapter instead of a nexiq solves these kinds of issues ... I have seen this before. * Wrong J1939 terminating resistance will cause the flash to fail. * is it failing in exactly the same place every single time?? or randomly?. * are there a lot of re-send errors before the failure?. * have you tried forcing it into run mode and flashing it with CT? .. watching how many retries it does along the way?. * Is engineering mode turned on?... It should not be for flashing one. --= and of course, it could be a block of memory in the ecm that is simply going bad too. ==- * How old is the ecm?. If it is more than 8+ years old then buying a new ecm is not a waste of moneys... as it has lived longer than its design life any ways. RE: Cm870 tuning issue needs some help - Sledpuller - 02-03-2023 (02-03-2023 )Rawze Wrote: I was asked about this earlier this evening. I know that different programs, etc. were tried, so it is not likely the program itself, however it can be the laptop or other hardware. Using a different computer, different adapter (cummins instead of nexiq) and/or different flash method might reveal the issue. Things like switching to the J1708 (or J1939 can bus #2) thru the dash etc. instead of a bench harness, etc.. sometimes yields different results. It’s failing at the same point every time no matter if we use the bench harness or the data plug in the truck. 70% every time. We tried switching to j1708 but it would not connect to the Ecm. I don’t know how old the Ecm is. No errors that I see before failure. The rest of your questions I don’t have an answer for as I’m not well versed enough to understand and answer correctly. Thanks RE: Cm870 tuning issue needs some help - Sledpuller - 02-04-2023 Problem solved. Using a Cummins, in-line, six adapter and the tune loaded to the Ecm. Thank you running rough for your help and patience! RE: Cm870 tuning issue needs some help - Rawze - 02-04-2023 (02-04-2023 )Sledpuller Wrote: Problem solved. Using a Cummins, in-line, six adapter and the tune loaded to the Ecm. Thank you running rough for your help and patience! Thanks for the follow-up. Yeah, I have seen where using an inline adapter prevails on occasion. It is always best to own both if your going to do a lot of flashing of ECM's. |
