| code 0951 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: code 0951 (/showthread.php?tid=8727) |
code 0951 - Neighbor - 02-03-2023 2007 cm 870 engine code0951 pid 166 spn 166 3 inactive counts with no lamps, smokes and smells like a little bit of fuel. Did not see anything when doing the cylinder cut out test or balance test. did have this similar problem last year ended up replacing cylinder 1 and 5 injectors and metering and timing actuators, which now have about 175000miles on them, should i do a bubble test and check actuators again. Engine was rebuilt and Tun$ed by Mr Hag down in GA 2 yrs ago and follow all the recommendations from this site about maintance RE: code 0951 - Rawze - 02-03-2023 run the overhead valve adjustment and do a bubble test... ref: http://rawze.com/forums/showthread.php?tid=7747&pid=67948#pid67948 |
