QuickServe Dataplate Info - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: QuickServe Dataplate Info (/showthread.php?tid=8732) |
QuickServe Dataplate Info - multitask - 02-07-2023 Gentleman, Just wanting to clarify some information on an engine. In QuickServe there’s two sets of dataplate information. In the build plant section it says UPF - distributor upfit. Does that mean the truck has had an engine change? First row states 500hp now is this an efficiency or performance engine? Is it safe to boost up to 600? CPL 3574. TIA RE: QuickServe Dataplate Info - Rawze - 02-08-2023 (02-07-2023 )multitask Wrote: Gentleman, the cpl did not change.. so it its the same tier as it was before. RE: QuickServe Dataplate Info - multitask - 02-15-2023 Hey Rawze, can this engine be turned up to 550-600? Thanks again RE: QuickServe Dataplate Info - 99xpress - 02-20-2023 yes it can turned up to 550 or 600. |
