| Engine fan intermittent won't turn off - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Engine fan intermittent won't turn off (/showthread.php?tid=8743) |
Engine fan intermittent won't turn off - Trey7981 - 02-16-2023 The fan cluth is good. The problem is at the solenoid air valve. Can some one tell me what activates the solenoid? And what volts and amps should be at the plug? Trying to test if it's the solenoid or a bigger problem. RE: Engine fan intermittent won't turn off - Rawze - 02-16-2023 check on insite software to see if it is being commanded on or off when it is acting up. Otherwise you are just chasing your tail on it. most common issue with intermittent fan clutch is actually the AC pressure switch. If it reads 0 or too high.. then the engine fan comes on. This means that intermittent connection, corrosion in the plug, or a bad sensor will cause your symptoms. RE: Engine fan intermittent won't turn off - Trey7981 - 02-16-2023 Last night when I was checking the solenoid. I did notice my ac clutch was engaged even though I had the heat on. RE: Engine fan intermittent won't turn off - SquareOne - 02-16-2023 (02-16-2023 )Trey7981 Wrote: Last night when I was checking the solenoid. I did notice my ac clutch was engaged even though I had the heat on. This is normal. Compressor will cycle in order to dry the air out otherwise you will create plenty of moisture from introducing heat alone (i.e. fogged windows) in the cab. Typically you notice this when you run the defrost option. The default on the defrost selection will engage the a/c compressor in order to dehumidify the air and assist in removing the fog from glass. |
