| prostar info center no longer readable and brake lights stay on - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: prostar info center no longer readable and brake lights stay on (/showthread.php?tid=8772) |
prostar info center no longer readable and brake lights stay on - BCODERRE - 02-28-2023 Anybody had a problem with info center on prostar becoming unreadable? when I bought the truck 1.5 years ago with 250,000 miles on it, itwas abought 75% readable but now I can,t even see the milage. Also started having dead batteries. Found that when the key was turned off the brake lights would come on. Now they stay on all of the time. Unplugged the brake switch but that didn't shut them off. Found the relay for the trailer brake lights which did shut off the trailer brake lights but can't find a relay for the tractor brake lights. Any info would be appreciated. btw truck still only has 260,000 miles. RE: prostar info center no longer readable and brake lights stay on - tree98 - 03-01-2023 Sounds like maybe a flakey cab controller. RE: prostar info center no longer readable and brake lights stay on - Rawze - 03-01-2023 before you get too carried away, you need to replace all the fuses (not the breakers or relays) in the fuse panel.. even if they might all check out good. it sounds silly, but prostars are notorious for tarnished fuses causing all sorts of cab controller gremlins. here is some reference to this... ref: http://rawze.com/forums/showthread.php?tid=1514&pid=12861#pid12861 Prostars are also notorious for letting rain water into the cab controller under the panel too. Causes a lot of cab controller and dash cluster gremlins too... ref: http://rawze.com/forums/showthread.php?tid=1962&pid=16882#pid16882 RE: prostar info center no longer readable and brake lights stay on - BCODERRE - 03-01-2023 Thanks, I'll be doing that today. RE: prostar info center no longer readable and brake lights stay on - BCODERRE - 06-17-2023 late update, replaced instrument cluster with used from vanderhaags. works fine except my milage reading changed from 271,000 to 611,000. must be a way to change that but ok for now. Brake light problem was BCM. bought reman from international. now no signals. brought to international and they did $3000.00 worth of diagnostics only to find out that the BCM was bad. That's what I suggested was the problem to begin with. replaced again and all set now. Also I sealed the cab because the entire left side floor both front and back in side compartment was very wet. Thanks for the info. |
