| need help - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: need help (/showthread.php?tid=884) |
need help - wolverine - 09-15-2016 i have a 2011 t-660 kw w/450 isx cummins no def! red engine light comes on while driving and sometimes while idiling! but never shut the tk down been going on for about a month now! my yellow check engine is on and display crankcase pressure. i changed the sensor and filter still on! had new egr.dpf filter and catalyst installed. the tk dont have def fluid! RE: need help - Rawze - 09-16-2016 Sounds like it could be a wiring issue with the crank case filter sensor, or an excess blow-by issue. Have you done any kind of tune-up work to it? Performed an EGR tune-up? replaced any sensors for the EGR? How much oil does the engine use? miles on engine? |
