| Gauges not sweeping - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Gauges not sweeping (/showthread.php?tid=8854) |
Gauges not sweeping - Satch - 04-14-2023 Where should i begin to look if my gauges don't sweep? When key on, the truck is doing the warm up clicks abs huffs. I noticed the gauges don't sweep anymore. Any suggestions? RE: Gauges not sweeping - Rawze - 04-15-2023 maybe the cab ecu or gauge cluster is not shutting down all the way for one reason or another?. RE: Gauges not sweeping - Satch - 04-16-2023 (04-15-2023 )Rawze Wrote: maybe the cab ecu or gauge cluster is not shutting down all the way for one reason or another?. I'll check area near cab ecu. Thanks |
